(SOLD) Tsunami fused dist block/volt meter - Car Audio Classifieds!
Old 02-23-2011, 09:31 PM
0/11 ssssss467
Default (SOLD) Tsunami fused dist block/volt meter
tsunami model number tpfdb-4pg
2 0 gauge in power 1 0 gauge in ground... 4 4 gauge out fused power out... 4 4gauge ground out with voltmeter
new never used /however no oringal packign
Reduced 45$ shipped!
Old 02-23-2011, 10:49 PM
0/11 ssssss467
picture of it light up
Old 02-23-2011, 11:40 PM
0/11 ssssss468
Just curious - what exactly do you hook up to see the reading?
Old 02-23-2011, 11:52 PM
0/11 ssssss467
if you hook up power and ground like you would normally... its actually 3 things in 1 .. a fused power dist block a ground block and a volt meter...
Old 02-27-2011, 04:17 PM
0/11 ssssss467
reduced 45$ shipped
Old 03-01-2011, 04:13 AM
0/11 sssssss42
So does distribute a total of 8 4g outs? Like 4 neg and 4 pos? Or is it only 4 total, and either full pos or neg? Interested
Old 03-01-2011, 01:51 PM
only126db's Avatar
The One U Love 2 Hate
0/11 sssss2943
Here I'll help OP out....
  • Tsunami TPFDB-4PG Power Fused Distribution Block
  • Two 1/0 or 4 gauge positive inputs
  • Four 4 gauge or 8 gauge positive outputs
  • One 1/0 or 4 gauge negative outputs
  • Four 4 gauge or 8 gauge negative outputs
  • Built-In digital voltage meter
  • 4 Position mini ANL fused
  • Bright nickel-plated finish
  • Unique over/under bi-polar design
  • Wireguide connections
  • Low profile compact design
  • High temp polycarbonate cover
  • Recessed internal mounting
  • True gauge reducer
Distribution Block TypeFused
Maximum Number of Inputs2
Maximum Input Gauge Size1/0
Maximum Number of Outputs9
Maximum Output Gauge Size1/0
Number of Fuses1
Fuse TypeMini ANL
Old 03-02-2011, 01:36 AM
0/11 ssssss467
thanks only
Old 03-02-2011, 05:24 PM
0/11 sssssss42
If thsi is still for sale i may be interested, i dotn have pm you can email me at [email protected]
FS: 4 fused dist blocks $10 each qbert Wiring, Electrical & Other Installation Equipment 1 10-13-2010 01:48 AM
[sold]Stinger fused disto block CLNFREAK Wiring, Electrical & Other Installation Equipment 9 04-21-2010 08:28 AM
1 Stinger Pro Distro. 1 Directed Fused Distro w/ Digital Volt and Amp Meter. its_ray_ray Wiring, Electrical & Other Installation Equipment 22 03-16-2010 10:28 AM
[SOLD] 5 1/0 in/out fused distro block-custom toolmaker Wiring, Electrical & Other Installation Equipment 11 09-25-2009 04:45 PM
[SOLD] Tsunami digital fused distribution block extremechevyman67 Wiring, Electrical & Other Installation Equipment 3 05-02-2009 06:15 PM
