FS: Professional Subwoofer Enclosure for 2 12s - Car Audio Classifieds!
Old 04-05-2011, 11:20 PM
0/11 ssssss186
Default FS: Professional Subwoofer Enclosure for 2 12s
1 Professional Subwoofer Enclosure (box) for 2 12" subs
This was built by DLDesignz aka Bassman3 or Dustin
37W x 18H x 20D
2 12" openings
1 port tuned to 30Hz
Like new, never used, never had subs screwed in, and only about 6 months old.
$185 plus shipping
NO TRADES please.
Others available upon request.
Old 04-05-2011, 11:22 PM
0/11 ssssss186
I forgot to add that the white marks are just chalk. I marked them so I could drill holes for the screws.
Old 04-06-2011, 03:07 AM
0/11 ssssss186
Okay, I used Torres' Box Tuning Calculator and this is what it said after I put all of the dimensions in:
------Box-------
Box Height: 18"
Box Width: 37"
Box Depth: 20"
----Port-----
Port Height: 13.75"
Port Width: 3.75"
Port Length: 20"
Physical Port Length: 15.50"
Baffle Thickness: .75"
Gross Volume: 6.27 ft3
Port Volume: .89 ft3
Port Area Per Cubic Foot: 9.5 in2
Port Area: 51.56 in2
Net Volume: 5.38 ft3
Tuning Frequency: 31.56 Hz
So, guess I was wrong on the tuning.
Old 04-06-2011, 03:20 AM
omgitscollin's Avatar
0/11 ssssss984
can you please specify if any silicone, resin, etc was used might have a buyer for you
Old 04-06-2011, 03:22 AM
0/11 ssssss186
I will double check with the builder and get back to you ASAP. Thanks.
Old 04-06-2011, 04:06 PM
0/11 ssssss186
This is what Dustin, the builder said:
"I don't believe I put on any silicone or resin, the enclosure is internally airtight because of the glue that is spread around each inner surface."
But, I believe he did use some silicone. Please let me know if this helps. Thanks.
Old 04-07-2011, 05:25 PM
0/11 ssssss186
bump for omgitscollin
Old 04-08-2011, 07:51 PM
0/11 ssssss186
Night bump
Old 04-09-2011, 11:49 PM
0/11 ssssss186
bump
Old 04-11-2011, 07:11 AM
0/11 ssssss186
New low price $165 plus shipping
Tags
dldesignz, sub box, sub enclosure, subwoofer box, subwoofer enclosure
Woodlawn Cabinetry Subwoofer Enclosure Fabrication MrCabinetry Wiring, Electrical & Other Installation Equipment 1 04-15-2011 06:48 AM
15" subwoofer enclosure CHEAP BIRCH!! Mendon Mafia Wiring, Electrical & Other Installation Equipment 11 08-23-2010 10:39 AM
2 15" subwoofer enclosure Houston area 4 18"FI ssd Wiring, Electrical & Other Installation Equipment 4 06-12-2010 01:36 PM
I'm not a professional but..... 92K1500 General Automotive Chat 11 07-17-2009 12:17 PM
15" Exile Subwoofer with Enclosure jamesjames66 15" Subwoofers 2 07-06-2009 01:54 PM
