FS: Pair of 8" MDF 1/2" rings - Car Audio Classifieds!
Old 04-08-2011, 11:33 PM
0/11 ssssss825
Feedback Score: 24 reviews
Default FS: Pair of 8" MDF 1/2" rings
1. Product: 1/2" MDF rings
2. Specs: The ring with the outside burnt has an outside diameter of 8.25" and an inside diameter of 7".
The other ring has an outside diameter of 8.625" and an inside diameter of 7".
3. Description/Condition: I just cut these today from leftover 1/2" MDF I had laying around. They are new and never been used but not perfect. Its hard to see in the picture but the outside and inside edges have groove marks from the stop and go of the router. I mounted the router in a way so that I could cut these myself with no help however I ended up needing to stop every once in a while to readjust my position and keep cutting.
This pair in particular is a bit different in that the outside diameter of the rings don't match. However the inside diameters do match. Also as you can see outside of the ring standing up in the picture is burnt all around from the router bit being too worn out. Even so its still rather smooth as it is. Just PM if you would like to see close up of the rings to show you what I mean.
4. Price: $5 for the larger (in diameter) unburnt one shipped in the U.S.
$4 for the smaller (in diameter) burnt one shipped in the U.S.
$8 for both shipped in the U.S.
Old 04-10-2011, 05:57 PM
0/11 ssssss825
bump
Old 04-11-2011, 10:49 AM
beatnbronco's Avatar
0/11 sssss2284
can you make flush mount mdf rings? i need 4-8" flush mount rings for door pods
Old 04-11-2011, 05:47 PM
0/11 ssssss825
Normally I would be able to, but my router bit broke so I can't at this moment. Sorry.
Old 04-13-2011, 07:49 PM
0/11 ssssss825
bump
FS: Pair of 4" MDF 1/2" rings YouSirName Wiring, Electrical & Other Installation Equipment 13 05-13-2011 09:09 PM
FS: Pair of 6.5" MDF 1/2" rings YouSirName Wiring, Electrical & Other Installation Equipment 8 04-25-2011 12:13 AM
FS: Pair of 4" MDF 3/4" rings YouSirName Wiring, Electrical & Other Installation Equipment 3 04-13-2011 07:57 PM
FS: Pair of 8" MDF 3/4" rings YouSirName Wiring, Electrical & Other Installation Equipment 1 04-10-2011 06:05 PM
FS: Pair of 6.5" MDF 3/4" rings YouSirName Wiring, Electrical & Other Installation Equipment 1 04-10-2011 06:05 PM
