Over drive - Car Audio Classifieds!
Old 04-20-2011, 12:36 AM
noknok's Avatar
0/11 sssss1521
Default Over drive
1. Product: audio control over drive
2. Specs: 9 volts rms-13volts peak
freq responce 10hz-100khz
thd 0.005%
sinal to noise ratio 110db
input impedence 20k ohms
output impedence 45 ohms
input gain 0-24db
power sipply transformer isolated PWM CD/DC converter
power draw 150ma
recommended fuse rating 1amp
size 5x4.25x1.25
weight 2lbs
balenced differential inputs
input ground isolation jumpers
output ground isolation jumpers
9-10 looks since its been installed (10min)
10-10 working condition
was imstalled but only for testing so the mounting tabs are still virgin.
4. Price: :75 shipped
Old 04-20-2011, 02:18 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
I'm thinking about this, I need to do some more research and I'll let you know.
Old 04-20-2011, 02:20 AM
noknok's Avatar
0/11 sssss1521
no problem... lmk
Old 04-20-2011, 02:49 AM
fiji24's Avatar
0/11 sssss1826
Might as well ask,
What does this do? lol
2003 Chevy Trailblazer
Subs- 4 Fi Q 12's
Amps- Sundown 3500D & Rockford Fosgate Power T400-4
Mids- 2 Peerless 6 1/2's Nomex Cone HDS Woofer
Highs- 2 Bohlender Graebener Neo8-PDR Planar Transducers
Headunit- Alpine CDA-9835(ACTIVE)
Old 04-20-2011, 06:39 AM
ampjunkielikeme's Avatar
GOT AMPS ?
0/11 ssssss381
Feedback Score: 17 reviews
Originally Posted by fiji24 View Post
Might as well ask,
this is a line driver . it boosts the rca voltage that comes out of your radio up to 9-13 volts....most cd players are only 2 -4 volts..
Old 04-20-2011, 10:47 AM
noknok's Avatar
0/11 sssss1521
thank you sir. ...
Old 04-21-2011, 06:12 PM
noknok's Avatar
0/11 sssss1521
bump
Old 04-21-2011, 06:19 PM
0/11 ssssss125
So in other words you don't have to turn the gain up much on your amps?
Old 04-21-2011, 06:23 PM
noknok's Avatar
0/11 sssss1521
yes it cleans out the signal also, and doesnt clip as fast.. most ppl that i see running this have also gained in spl by as much as 1 db that iv seen..
Old 04-21-2011, 08:41 PM
noknok's Avatar
0/11 sssss1521
pending sale
db drive bulldog101 Tutorials & Quick References 5 11-01-2011 08:26 AM
db drive bulldog101 Car Audio Product Reviews 5 05-08-2011 08:58 PM
4wheel drive vs 2 wheel drive fuel economy? F3M4 General Automotive Chat 8 01-29-2010 04:04 PM
dvd rom drive fatpat1080 Miscellaneous Stuff For Sale 2 06-16-2009 01:33 PM
