1 - 4 of 4 Posts
1. Product:Two Digital Designs 3510f Subwoofers
Specifications
Magnet Weight 240 oz
Nominal Impedance D4.0 Ohm
Power Handling (RMS/Peak) 600w-"1200"w RMS, 4800w Peak
Suspension Travel 80 mm
3510f
Fs 30 Hz
QTS 0.303
Qes 0.324
Qms 4.742
Shipping Weight 34 lbs /
VAS 20.680 L
Voice Coil Diameter 3"
Woofer Diameter 10" / 25.4 cm
A - Outside Diameter 10.63 12.625 15.375 18.25
B - Cutout Diameter 9.25 11.25 13.75 16.75
C - Mounting Depth 7 7.5 8 9.5
D - Motor Diameter 7.69 7.69 7.69 9.69
E - Motor Depth 3.38 3.38 3.38 3.38
F - Outside Height 1.06
The Subs are BRAND NEW IN BOX never connected to power or mounted. They are Fully upgraded, including Supercharging, Carbon Cap, and SQ suspension. The intended use for these woofers was in an SQ build. I didn't want to sacrifice the fun factor though so instead of buying a strictly SQ woofers i built good sounding DD woofers. Well i'm leaving for the air force and the build is on hold so they are for sale. I'd be happy to answer any questions.
4. Price: 950 for the pair shipped and insured to the anywhere in the CONUS :
1 - 4 of 4 Posts
