are you sure thats why your amp was cutting off cus of the voltage? whats the voice coil config of your t2000's if they are dual 2 you might be running your load down to .5 ohms and that could be why its shutting off also.
Also could be shutting off do to a loose ground!are you sure thats why your amp was cutting off cus of the voltage? whats the voice coil config of your t2000's if they are dual 2 you might be running your load down to .5 ohms and that could be why its shutting off also.
