2015 Chevy Silverado LT
Double Cab
4x4
Heated Seats / Mirrors
Auto Start
LOTS of extras.
List of work done off the top of my head:
Oil and filter changed regularly before 40% oil life.
K and N Black Edition Air Intake
Flow master original 40 muffler with dual exhaust with stainless tips.
All 8 coil packs replaced with NEW OEM part number per TSB.
All 8 iridium spark plugs changed
Regularly cleaned throttle body and ran Seafoam through gas tank to ensure injectors/fuel system stay clean.
Large heated tow mirrors with turn signals and reverse lighting installed
Replaced rear bumper and had the shop paint it black to match the truck.
Drilled and Slotted rotors and performance brake pads
All LED lights on truck for better visibility
All aluminum radiator, HD hoses, 194 thermostat, fluid change
Transmission thermostat replaced with 158 thermostat per TSB from Chevy + all new trans fluid
Differential and Transfer case fluids changed
4 BFGoodRich All-Terrain T/A Tires with warranty Discount Tire
2.5" Lift in the front to level the truck
APS Black Running Boards
Tyger Auto Fender Flares installed and removed the plastic mud flaps since snow/ice buildup had cracked them.
Weathertech front and rear floormats and bug guard.
Bakflip hard foldable bedcover, and bed had bedliner installed by Chevy.
Very LOUD Audio System:
2 X2 SLI94RAGMDP Batteries Made by NorthStar
Used all 4/0 wiring (not 4 gauge)
8 PRV Tweeters TW500My-Nd
8 PRV Mids 8MR500CF-NDY-4
2 Sundown Audio subs SD-4 Custom sub box with SILVERADO embossed
Powered by: 3 PRV 1200.1 amps 1 PRV 1200.4 amp 1 AudioControl DM-608
Custom door panels in each door.
Roof, all 4 doors, and rear cab sound deadened.
4 Stinger volt meters installed on each amp power inputs
Digital Oscilloscope wired to the subwoofer input of the bass amp to view the signal, and Microsoft Surface (removable) which I use to log into the Audio Control to adjust sound settings: can be included if the right price is agreed upon.
Lots more I'm sure I may be missing but I am meticulous when it comes to my vehicle maintenance. All paperwork that I have readily available will be included.
Here is my listing on facebook:
Войдите на Facebook
