2500+ @ 2 or .5
771 Views 17 Replies 15 Participants Last post by  Inferno333
Product I'm looking for:
Amp that will do 2500-3500 @ 2 or .5ohms..I realize .5 is the most likely scenario.
Budget: $400ish..
Condition: Look - decent, works 100%
Time Frame (if applicable):
ASAP
1 - 18 of 18 Posts
Why not an AP3k? They do 3k @2ohms
aq2200d should do 2500rms at .5 ohms
I like the aps and just bought another 1500 but if you already have the subs for that coil config. the aq2200 is a better buy. it will be workin just hard enough at .5 after rise to get you 2500+ and wont overheat or run hot with decent electrical. The ap3k however will never do 3k if you wire it to 2 ohms, and barely ever get warm and clamp about 1600-1700 max if you have 2x rise.
I dont care if ppl say rise is not an issue but every clamp test i have done shows 2-3x rise so I always try to match it up to about 50 - 75% starting load compared to rated load. depending on the amp quality and electrical support
aq2200's love .5 before rise - all day
ap3ks love 1 before rise - all day and will clamp 3k with some mild clipping but will suck a ton of juice
2500 @ 2ohms
Here's a Kicker zx2500.1. It's in your price range. You can prolly work out something with the seller. Good luck with your search.
lnib kicker zx 2500.1 fs/t - Car Audio Classifieds
Hmm.. so you say an amp that does 3k will only do 1600~1700 watts when it rise is to 4 ohms...but it doesnt do 3k.. Wire any 3k amp to is rated load and see if you actually get 3k out of it after rise.
Memphis Mojo 2k (orange flame)
$300 shippped
2000 watts at 2-ohm
(2) Memphis Mojo 2k's - (orange flame) - Car Audio Classifieds
brutus bxi2610 250.00
crunch gp300pro would work
blown soundstream rub2500.1 220 shipped
I need help as well. have two re sx's. kinda stuck between a sundown 3000d or an aq2200. ive had aq in the past and was extremely happy with it's power and reliability. but then again sundown is a little bit more power at .5 so opinions please?
American Bass VFL 150.1
This is from the clamped numbers thread on here.
-.4 ohm nominal. Rise to 1 ohm exact
-drop to 13.3
-2,981 watts
Looking to get $390 shipped. OBO
i have a kicker zx2500.1 for $400 plus shipping
Both of the above are interesting..I actually picked up an AQ2200 but might want something a little bigger
1 - 18 of 18 Posts
