im trying to come up with a box design for (4 Power Acoustik MOFO 15's) each sub will get 1000rms i have 4ft between the wheel base an can be up to 7 foot in length (if needed) wanted to go with a port (open to suggestion) i have a 1994 astro van
crunch 2000.1 ( class ab 120a fused) does 2000 rmsWhat kind of amp? Please dont say Power Acoustik
Sent from my DROID RAZR using Xparent Blue Tapatalk 2
if the amp is rated at 2k and you have 4 subs....my math says they will be getting a max of 500w each not 1000.or do you have 2 of those amps?crunch 2000.1 ( class ab 120a fused) does 2000 rms
A astro has so much room.... here is one for you that works well with both the earlier gen with the 4" coils and the newer X series with the 2.5 coils.im trying to come up with a box design for (4 Power Acoustik MOFO 15's) each sub will get 1000rms i have 4ft between the wheel base an can be up to 7 foot in length (if needed) wanted to go with a port (open to suggestion) i have a 1994 astro van
