91 crx build log
3008 Views 56 Replies 7 Participants Last post by  jackdaniels
2
alright guys time for a build log. to start this off we have a 91 crx purchased without a dash front bumper and needing a trans. the trans has been fixed and the car runs good so now starts the audio section of the build.
we will be running 2 re se15 on a audiopipe 3k. the 15s we have had and the 3k has been ordered we will run 2 runs of 0g 1+ 1- for now. we will continue to add until we see no more gain. i will be building 3 boxes for this. one sealed to find out where im at frequency wise. one for daily beating tuned around 30-35hz and one at the top frequency more than likely built subs forward 10" pvc back...
the car will be deadened completely until we sain a loss. we will be shooting for numbers in this mainly as classes around me get pretty competitive.
i will be painting the wheels black also blacking out the tails and putting a oem bumper on it. the car will get tinted and repainted flat black. after some body work gets done.
tomorrow i will be starting on doors while waiting for the audiopipe to arrive b4 i start testing so i can have some power. the plan is to eventually run 2 sundown 3500s on 8 sa8s.
here are what pics i have so far my camera is at the shop or id post the vids of a us amps xt4000 and 2 15s did to the windshield already at 30hz lol lets just say the small crack it had now takes over the windshield.
1 - 20 of 57 Posts
you should go with 10s or 12s , crxs tend to like smaller subs , loudest design was 4 12s 2 forword 2 top and port back
I am going to be doing my own build log. With a 91 crx. Two 15" two amp and two battery spl. Street c
i have considered 4 12s. we are going to play with the 15s and see what kind of number we can get off of what we have for now...
i might get sick of it and drop in 2 10s and run street a or i might say screw it and just do bass race. it all depends how testing goes. i have heard some peak in the high 50s and iv seen a few that peak at high 30s low 40s depending on where mine is is where i go from there.
interested to see what you come up with.
mine peaks at 61 hzz , i run in ss nw hoping for some big numbers at finals next month , if ur deadning the car deadn the roof the doors and everthing behind the b pillar leave the flooor test then do***ent your score then deadn the floor and see if the score changes some crx gain without deadning on the floor
what about the firewall? any ideas on if i should cover that or not?
leave the entire floor/firewall bare everything else doors , roof , everything behind the b piller done test then do parts of the floor see if it gains or goes down most ppl say leaving the firewall non deadned gains it gained me in my car
sounds good i just ordered 300 sq ft to do the crx and yukon
right on man go with a huge port 8.5 inches or 3 6s tunning port length is a huge gain in the crx
does anyone make alts for these cars? i read somewhere about using a gm large case i beleive but didnt have much details
i have a xs power 250 amp alt bolted right on
gm or honda?
honda i have a 89 crx the brackets come with the alt and bolts on works for 88/91 rexs xs power kicks ass
yeah i plan to order 4 3100s for the back just for daily.
i might pull some specs tomorrow and have someone local fab up a dual alt kit where the ac was
sounds good man looking forword to this build ill post pics of my new build once im down got the rest of my stuff coming this week if all goes well i should see some nice numbers out of the crx this year ''
good luck this season...
thread will be more updated tomorrow with pictures. ill be starting on the falso floor to level the back out tomorrow
thanks man if i was you id lay carpet in the wheel well leave it open crxs like alot of room for airflow
spare tire will stay open im going to build the front shelf rght behind the seats where the cargo area is and make it solid not plastic..
add me on facebook ill show what i did in my car
luke paddle is my fb
1 - 20 of 57 Posts
