1 - 20 of 25 Posts
American Bass VFL 700.1​
(1 of 4 made and has different case than tn other 3.)
Specs:
1 x 2150W @ 4 ohms (14.4V -1% THD)
1 x 3800W @ 2 ohms (14.4V -1% THD)
1 x 4700W @ 1 ohm (12.5V -1% THD)
1 x 6500W @ 1 ohm (14.4V -1% THD)
1 x 7000W @ 1 ohm (14.4V -2.2% THD)
1 x 7300W @ 1 ohm (16V -1% THD)
1 x 7800W @ 1 ohm (16V -2% THD)
1 x 8600W @ 1 ohm (18V -1% THD)
1 x 8800W @ 1 ohm (18V -2% THD)
Signal to Noise : 85dB Damping Factor : 250 Efficiency : 74% Dimensions: 30.31 x 11.22 x 2.76 inch. (77cm x 28.5cm x
of only 4 made and this one is the only one with a different case This amp is in Tip top shape mechanically as I had it repaired correctly as one of the power supplies was starting to go out and went ahead and had 2 replaced, new mosfets, gate resistors, and drive transistors, along with some extra sauder points on the connections to make the amp. It has been fixed correctly and I took a quick video and pics to show that it was done to AB Specs or better.
AS of 3-2-11
NOW only $895 shipped in Cont US only
Will consider trades on good 3-4k amps like DDM3, atomic, cactus, and am looking for 6 8" DC sound Labs Lvl2, SA8's x6, soundsplinter or tc 8s or 12's
[/SIZE]
Discussion Starter · #2 ·
Offers?
wonder where the other amp is that was a pair in one of our team shocker cars in 2006,there were 2 of them strapped in st a .
Not real sure, but wish I had the money to have two of them as I dont want to get rid of this one I just need to.
Wangin' Out
trade for 2 custom tc9 12s?
Sent pm as I just now seen your post and I am very interested in working something out.
hey do u still have this amp also if u do is this amp half ohm stable ??
Yes I still have this beast and you can run it at .5 ohm daily but gotta keep the voltage up just like any other amp.
gettin it in
15" IA death penalty d1 excellent condition, and a sundown saz1500 mechanical 10/10, cosmetic 7/10 never seen power below 14volts
New Price
$935 shipped & fully insured
(Con US only)
TTT
$935 shipped
Discussion Starter · #14 ·
Discussion Starter · #18 ·
Discussion Starter · #19 ·
1 - 20 of 25 Posts
