pi(R^2)
And does that gives square inches?pi(R^2)
Yes, sir...as long as you use inches as the radiusAnd does that gives square inches?
lol, heres the forumlas to find the length needed and minimum PA required:
LV is Length of port
Dv = port diameter (cm)
Fb = tuning frequency (Hz)
Vb = net volume (litres)
Np = number of ports
k = end correction (normally 0.732)
Lv = (23562.5*Dv^2*Np/(Fb^2*Vb))-(k*Dv)
Sd = pi*(Dia/100)^2/4
Vd = Sd*Xmax/1000
MIN DIAMETER = 100*(20.3*(Vd^2/Fb)^0.25)/Np^.5
