Exactly. And you'll be drawing from the front battery a good bit. If you had a huge bank in the back, then multiple runs would basically be pointless. But you don't. You're depending on the combination of 2 batteries to power your setup, which means they need to be as close to 1 battery as possible in terms of resistance. This means more wire.
