Aq3500 how many batts
1779 Views 22 Replies 11 Participants Last post by  sruggles1976
I havean audioque 3500 on two t3 t2000 15's dual 2's I'm runnin it at .5 ohm how many batts do I need for te amp to keep playin all day with no cutting off???
1 - 20 of 23 Posts
HO alt and 2 G31 batts will do the job...batts alone won't let you play it all day long
Ok I just got a 220amp alt a kinetik 800 a deka intimidator a yellow top optima for under my hood and a nsb 125 battery will that allow me to play all day with no cutting out
nope
That nsb battery is bigger than 2 kinetik 2400 that still won't be enough what else do I need before that
2 2400's> 1 NSB 125 :thumbsup:
That NSB is plenty for what he has.
You are wrong.
So do I need another battery? Is my alternator good enough?
My nsb125 along with my deka g31 intimidator and my kinetik 800 and my yellow top that's not enough?
all those batts along with an HO alt should be plenty to play full tilt for long periods of time....
You have plenty battery.
Don't worry.
Hey FEMA will I be able to play it .5ohm all day without any cutting off?
sell the yellow top and 800 and get some more deka's or another nsb125. thats just my .02
You are wrong.
Only way he will be fine is if he enjoys toasted insides running a AQ3500.1 at .5ohms daily is no small chore..
With your electrical, if it cuts off, it will be from heat, not voltage.
He doesn't need anything else.
Telling him to go out and spend more money on batteries is a waste. He is fine, and will be fine voltage wise.
You are wrong.
Correct. I laugh when people think they need 3 or 4 big batts and multiple alts for 4kw
Do u think I should put a cooling fan by the amp
i run my aq3500 @ 1ohm off a stock 135a alt with an optima blue top up front (for the added posts :D) and a nsb 100ft in the rear, i can play it full tilt while driving all day no problem, if i play it @ idle i start to have voltage drops after a short time but with your added batt capacity and ho alt you should be fine going full tilt all day as long as your driving and not @ idle.
edit: if the amp is getting hot, yes a fan would help, if its not getting hot it wont help...........
for info purposes one nsb90=one and a half kinetik 2400...so nsb125> 2 2400
1 - 20 of 23 Posts
