TDB 275
T H E R M I O N I C
Vacuum Tube Driven Mobile Powe
They sound like no other!
I Have 2 of these @400 $ each
Very low hours !
ZERO negative feedback. No global negative
degenerative feedback loop
Open Ended Audiophile Circuitry
Musical, warm and dynamic, rivalling "all-tube" single-ended home audiophile amplifiers
Hand selected/matched 6SL7GT Twin Triode tubes
(One per channel)
Fully regulated Tube Heaters with Delayed Soft Start
(10-15 second turn-on delay)
Load Adaptive Vacuum Tube Driven output circuitry
Massive (400% oversize) internal/external Heat Exchanger with Temperature-controlled Fan Cooling
Tightly regulated MosFET Power Supply
DC fault / Short Circuit Protection Circuitry
Dual Color Diagnostic LED: Green=Normal / Red=Fault
Gold Plated RCA, Power and Speaker Connectors
Frosted Platinum finish
Tube Illumination: Internal BLUE LEDs
Patented Design
Concept & Design: BK Butler / USA
Specifications:
Rated Power (all channels driven):
2 x 75 Watts RMS per channel @ 4 ohms
1 x 250 Watts RMS Bridged (Mono) @ 4 ohms
2-Ohm Stereo, 4-Ohm Mono Stable
Freq response: 5Hz to 100kHz (+/- 1dB)
THD: <0.15% (30kHz bandwidth)
S/N Ratio: >110dB (A-Weighted)
Idling Current: 1.8 Amps
Input Sensitivity: .450v - 12v RMS
Fuses: 1x30A ATC
Dimensions: 10.25"W x 13.8"L x 2.4"T
Weight: 9.5 Lbs.
