1. Product: Cache coe8 "8 Channel Summing and Line Convertor"
2. Specs: One of the difficulties in adding aftermarket amplifiers and speakers to an OEM system is having enough input channel flexibility to integrate properly with that systems output capabilities. With 4 pairs of independent channel inputs the coe8 provides nearly limitless install versatility.
The coe8 has a unique signal sense feature that detects signal on the input and turns the unit on without the need of a 12-volt trigger at the remote in (turn on) connection. Whether you are using the remote in or the signal sense function the coe8 has a remote out feature that will turn on your amplifiers or other devices.
All of the channels of the coe8 can be blended or summed to the main channel so even if you only have one pair of stereo inputs you can still use all four channels of output. http://cacheaudio.com/coe8.html
3. Description/Condition: Used for 2 weeks. Condition 9/10 Tried out several LOC and summing models and decided to go all active. Item was brought new and works perfectly.
4. Price: : Lowered to $90 shipped
** DO NOT DELETE ANYTHING BELOW THIS LINE OR THREAD WILL BE DELETED ** -----------------------------------------------
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Thank you for your interest in CarAudioClassifieds.org. A forum community dedicated to Automotive Audio enthusiasts. Come join the discussion about builds, modifications, troubleshooting, models, styles, reviews, classifieds, and more!
