$750 each or for both?
Should be fine. I never ran them lower than 1 ohm.Are these .5 ohm stable?
The way you have that posted it looks like peak is 5k at 1ohm but it is RMS. I have ran these amps, very stout. GLWS
Rated 5100W @ 18V. On a solid 14.4V setup you should expect to see 3500-4k depending on your rise.
thanks i didn't know that!C7 is nice but like all the ZRS series is rated at 18V
Only expect around 5K on 14V
this is similar and pretty much identical to power and efficiency as an rd audio d5...usaci rating is 600 @ 4ohm and great amp for stock or pro-stock 0 to 600
