41 - 60 of 89 Posts
Was wondering if you sealed off the Speaker leads going into the box? If they're just holes with the wire sticking through them I would think there would be some air leaking out of it.
Discussion Starter · #49 ·
actually there VERY tight inside there. it was a struggle to get them through...i could have went bigger on the hole but i made it slightly smaller on purpose and it seals itself. i rather do it that way than going through nuts and bolts adding slightly more resistance in the wire through medium change.
If it there's the slightest hole, air will escape through it. Why not just buy a little tube of silicon to seal it up for sure. Prolly about 3 bucks.
Are the angles in the port calculated,or ....? Did you change the port lenght because of the kerfed ports? Will be building an 18 box soon,and like your design.
The angles are actually figured into the length and diameter of the port. But not but just adding the total length or diameter. And I actually flare the outside opening of the port larger than the inside opening. There is a reason I do this in most of my boxes, and its an SPL secret.
There is no air leakage.
I usually use this stuff called wonder putty, its a 2 part epoxy putty that can be swuished into the holes around wires and such. There was no need here.
what's the name of the song in the jesus approves vid?
Very nice vids and build, and let me ask how do you like those new Rockford 2500s?
Discussion Starter · #60 ·
snow- Hip Hop Doctor-Lil Wayne
BigC-these amps are holding off NICE!! def got some power and the 2 combined are more efficient than my single T4k and putting out more power too :D
Ridnclean-im sorry but joo cant have Juanito...thats my mooonnkey
41 - 60 of 89 Posts
