1 - 8 of 8 Posts
i got 2 on the way and was wondering what size and kind of box would be best for both, they will be powered by about 4k right now and then i will be adding another amp. it will be all going into a grand cherokee
i would do 6-7 cubes per driver. should work out well.and i would tune around 32hz.
Or not! I wouldnt give them over 5... All ofthem that ive seen have done gret in small boxes! 5 cubes on the lower power side nd 4-4.5 on the higher ppwer side!
7 cubes is way too much!!!
id say around 5-6 cubes per woofer. more around 5 since i guess you will be adding another 4k for a total of 8k rms?
so subs up port back , or would you guys just wall it. i would do a wall but i like having a back seat
1 - 8 of 8 Posts
