Hello again, up for sale today is my D5 600.4
You all know this amp, tons of overhead, built like a tank. It's in great lightly used condition, refer to the pictures for condition, you will certainly be happy with it 😁
For those that want some specs:
  • 4 Channel 600 Watt Amplifier
  • Fully Regulated Power Supply
  • Up to 5V RMS Input Signal Voltage Capability
  • High-Pass Crossover: 12 dB/Oct. 50 Hz - 15 khz
  • High-Pass Multiplier: (x 10)
  • Low-Pass Crossover: Stereo, 12dB/oct. 50Hz - 5kHz; Mono (Ch 3/4), 24dB/oct. 50Hz - 5Khz
  • RCA Outputs
  • 2 oz. Silver Plated Copper Circuit Board
  • Massive Proprietary Heatsink
  • Vully Variable Electronic Crossovers
  • Nickel Plated SOlid Brass, Circuit Board Mounted, 4 Gauge Device Power/Ground Connector Blocks
  • Nickel Plated SOlid Brass, Circuit Board Mounted, 10 Gauge Direct or Banana Plug Direct Speaker Connectors
  • Fly Cut Aluminium End Plates
  • Fully Adjustable Mounting Feet
  • Crossovers Employ Second-Order 12dB/Octave Butterworth Filters
  • Dimensions: 17" L x 12" W x 2-3/4"
Asking $250 shipped
