I am going to be running 2 soundstream 1500D's powering to cascade omegas. Just wondering what i'll need to do for elecrical? Would i want to put extra batteries in the back? If so how many would you recommened? thanks
This is not true. The alternator is only ment to charge/maintain. You are better off spending your money on batteries with your set up.for the price of 2 small batts yer better off with one big batt hc2000 or hc2400. with a stock alt a batt is just a band aid on yer electrical.
i would first spend that batt money on a alt that will pretty much power the 2 amps.
its only gonna work as long as the batt has the reserve. once thats depleted the alt cant keep up with the current draw. then there is just gonna be bad voltage drops.This is not true. The alternator is only ment to charge/maintain. You are better off spending your money on batteries with your set up.
Here is a little artical you should read...:thumbsup:
http://www.zena.net/htdocs/alternators/AutoSound.shtml
