1 - 20 of 90 Posts
Ad ministrator
Could someone please explain to me why I need 1/0 power wire?
My dad seems to think 5ga is to big and now I'm upgrading to 1/0ga.
Could you list why my audio equipment needs this huge wire?
Idk what Im talking about
what does your setup consist of? And 5-gauge isn't too big for pretty much anything besides your remote wire or for a fan
Ad ministrator
My setup is irrelevant. Because I just want to explain to him that it NEEDS 1/0ga wire.
But anyways my setup is, a kickerzx1000.1 amp and 2 kicker l5s
Well, if you can prove that it draws 'X' current and also show that your smaller wire can only handle 'X' current...it'd actually be dangerous to use a small wire. So really it's safer and more efficient to use to 1/0 gauge on some level when fused properly..
Ad ministrator
Alright thanks, any way I can prove that lol?
Thanks for your help.
Wouldn't want to starve that ZX1000 and 5ga? is pretty thin.... especially if wired from front batt to a rear trunk....
Well, you can clamp the input wires for the amp and see how much youre really drawing...but you can just look up the factory specs and devide the power by voltage and see how much current that is (wont really be the current youre drawing for it but will be a ballpark for what youre drawing...youd have to factor in efficiency etc etc)
Distance is also a factor.
Ad ministrator
Clamping it? What you mean?
Using a DMM?
Ad ministrator
Discussion Starter · #14 ·
I'm not going to pay $250 just to prove to him lol.
He just thinks that 1/0 is too big and that he could use that kind of wire to wire houses lol.
Ad ministrator
Discussion Starter · #16 ·
I'm going to use a 300a fuse.
But I gotta go to work, thanks for the comments will bbl
If you want to PM me your email address, I have an excel file called the Audio Calculator. It has an area for you to input your info then follow the chart. Still not as accurate as clamping but still nice to have. There's gain control adjustment ... a couple other things too.
you probably have a 200 amp breaker box on your house and it's ac current not dc
dc requires more wire to carry the same amount of electricity so each breaker is probably around 20-30 amps each while amps pull more than that
A 300 amp fuse wired to a 5 ga line will catch fire. The purpose of the fuse is to protect the wire, .... well and equipment.. if something should happen to that wire the 300 amp fuse won't stop it from melting.
1 - 20 of 90 Posts
