1 - 7 of 7 Posts
Local Pick up only. No shipping. Located in the Inland Empire, CA.
Audioque 120.4
Specifications
Model AQ120.4
Dimensions 15.75" x 9"
Input Sensitivity 8V~0.2V
Low Pass Filter 50Hz ~ 5kHz
High Pass Filter 20Hz ~ 5kHz
Crossover HPF/FULL/LP-BP
Remote Gain Control Included
Clipping Display Led Yes
Signal to Noise Ratio 105dB
Damping Factor 200 <
Bass Boost @45Hz 0~18dB
External Fuse Rating 40A x 2 pcs
4 ohm power @ 14V 120Wx4
2 ohm power @ 14V 170Wx4
4 ohm mono power @ 14V 340Wx2
Power and Ground Inputs 4ga
New, never powered on.
$220
1 - 7 of 7 Posts
