One set (2 available) of like new condition boston pro 60 se components
Speaker Size
6-1/2"
Rated RMS Power Handling
125 watts
Nominal Impedance
3 ohm
Frequency Response (±3dB in car)
50Hz-22kHz
Mounting Cutout Diameter
5" (127mm)
Mounting Depth
2-3/8" (60mm)
Mounting Depth with Spacer
2-1/16" (52mm) System Type
2-way
http://www.bostonacoustics.com/Pro60SE-P601.aspx
I bought these speakers new, and after using them for about 2 weeks, decided i didnt like the sound of rear fill. they are in amazing condition, but i figure i should point out anything at all that makes these appear to be anything other than brand new. There is a tiny bit of rust on one of the screws on one of the crossovers. you only notice it if you try to. also, i soldered wire leads to the posts of the 45 degree mount bottoms. it will show in the pictures below, but basically the female spades sucked that they came with, so you will probably like that i did this. on the bottom of one of the crossovers, there is a little residue from some double stick tape i used. This can be seen in the two pictures below. All of these things are insanely minor, and i promise that you will be surprised by the good condition of this set.
With any questions, or counter offers either PM me, or email me. [email protected]
Im going to start at $245 shipped. OBO
Speaker Size
6-1/2"
125 watts
Nominal Impedance
3 ohm
50Hz-22kHz
5" (127mm)
Mounting Depth
2-3/8" (60mm)
2-way
