FS Kinetik HC16v battery
752 Views 12 Replies 5 Participants Last post by  thumper21
5
1. Product: ^^^^^
3 post 16v battery
3. Description/Condition: It has been sitting in my storage for almost a year now. I had purchased from SLAM(on here) and it works fine. It has a slight buldge on the left side but I was told it came from Kinetik like this(Does not affect performance). It rests fine and I'm sure could use a little charge.
email - [email protected] or txt (719)565-8590 for faster response
4. Price: : $120 shipped (in the lower 48)
1 - 13 of 13 Posts
Note the 16v means its a 16 VOLT battery. Not intended for stock electrical.
If you charge the battery at 16v can you use the 12volt for other accessories
You can but I would advise against it.
So you can't really use this as a voltage step down ??
You can if you have more then one. But to just use one battery to power a system at 16v and running the car off the 12v will kill the battery.
Exactly what audio said. Its better to run them like that in banks.
I was just thinking of using my 16v alt and use this batt up front charging at 16 having that run back to my other 16v batts in the back of my jeep then running all my engines computers and headlights starters ex.. off the 12v side of the batt will that work??
Only if the other 16v batts are similar 3 post kinetiks. That way you wire all the 12v posts together. These little guys don't have enough head room for one batt 12v post to run the entire stock electrical.
Bump
make offer
sold please lock
1 - 13 of 13 Posts
