1 - 20 of 25 Posts
im wanting sum low end up front, so i wanna put 2x 8" subs in my doors. whats a good sub thats low on mounting depth and has a freq responce down to at least 30-40hz. thanks
lol...well anything besides sonic electronics...kinda like to stay away from mainstream....i do like them earthqueake's tho
Idk what Im talking about
I have a pair of the pioneer shallow 8's that I bought years ago and have been untouched since then, from the very little I played one I would probably say they arent bad at all, pretty solid.
Ja Marcus
Those earthquake subs are bad ass. It is a perfect fit replacement for BMW's. We have installed quite a few at the shop.
wanna sell em ? LOL 4real tho
Discussion Starter · #9 ·
them earthquakes n them aura's are @ my top right now
Ja Marcus
You won't be disappointed. They have a nice rich full sound to them. Should compliment what ever you have quit well.
How much mounting depth are you working with?
5in TOPS...gonna glass lil pods in the pocket of my door in my 2001 grand am
man!!...for the price tho them dayton neos are nice i love the looks of em also and the specs are right @ what i want
This new 8” master piece High Definition Carbon Fiber subwoofers are easy to install very flexible subwoofers, easy to fit in multi size enclosures and offer special unique impedance wiring options. You can run these subwoofers in 4 Ohm, 2X2 Ohm stereo or 1 Ohm which ever impedance option suits your install the best. They fit in both small sealed and ported enclosures, call CDT direct for specific model enclosure design details. 1-877-568-3238
HD 800CF
8” Carbon Fiber Subwoofer
Technical specs and contents:
  • 1 e/a 8” Cast Carbon Fiber Subwoofer
  • Frequency response 10Hz-400Hz
  • Power handling: 200WRMS (400Watt Pk).
  • Impedance 4 Ohm
  • Sensitivity: 87.36dB
  • Mounting depth: 3.69”
  • Cutout diameter:7.43”
  • Cast frame: OD 8.27”
  • Cone: Carbon Fiber
  • Magnet weight: 25 Oz
  • Cone surround: NB rubber
  • Impedance: 2X2 Ohm
  • Voice coil: 1.52” (38.55mm) Fs: 45.9Hz
The only reason the Dayton's are not in my car is because I traded the 21" for a set of shallow 8's. They model up to be great little midbass drivers and they are damn sexy too.
I haven't heard earthquake and bad ass in the same sentence since way back when they made the Magma's
Discussion Starter · #17 ·
HD 800CF
  • Impedance 4 Ohm
how much them gonna put me back?!?!
Ja Marcus
LOL....You would be suprised at these little guys. Earthquake may have gone down hill in some areas. But these are still on par:thumbsup:
Features:
  • Electrical Q Value -Qes: 0.38
  • Mechanical Q Value -Qms: 4.21
  • Total Speaker Q Value -Qts: 0.34
  • Free Air Resonance -Fs: 22.8 Hz
  • Equivalent Compliance -Vas: 27.1 liters
  • One-Way, Linear Excursion -Xmax: 12 mm
  • Efficiency -SPL 1W/1m: 81.2 dB SPL
  • Effective Piston Area -Sd: 195 cm^2
  • DC Resistance -Re: 3.2 ohm
  • Nominal Impedance -Znom: Dual 4 ohm
  • Thermal Power Handling -Pe: 175 W
  • Force Factor -Bl: 15.4
Specifications:
  • Mounting Depth - 4.5"
  • Mounting Hole Diameter - 7.3"
  • Overall Diameter - 8.7"
  • Bolt Hole Circle - 8"
  • Motor Width - 4.875"
  • Motor Depth - 1.9"
  • Basket Depth - 2.4"
  • Displacement - 0.07 cu. ft.
REX-8D4 REX8 REX-8 REX8D4 - RE Audio 8" 250 Watt Dual 4 Ohm REX Series Subwoofer
Related Accessories
1 - 20 of 25 Posts
