1 - 6 of 6 Posts
1. Products:
(1) Sub Amp - Hifonics BXI2006
(4) Subs - BX12D2
Amp:
RMS Power Output: 1 x 650 W @ 4
  • RMS Power Output: 1 x 1300 W @ 2
  • RMS Power Output: 1 x 2000 W @ 1
  • Protection: DC, Speaker Short, Thermal, Overload
  • Power Supply MOSFET
  • Audio Output MOSFET
  • Dampening Factor: >250
  • Signal To Noise Ratio (A-weighted): >95dB
  • Variable Input Level Control (unbalanced): 0.2V - 9V
  • Input Level Control (balanced): 0.04V - 18V
  • Input Impedance (un-balanced): 47k-Ohm
  • Input Impedance (balanced): 20k-Ohm
  • Power / Diagnostic L.E.D.
  • Variable Low Pass Filter / 24dB: 35Hz - 250Hz
  • Variable Subsonic Filter / 24dB: 15Hz - 35Hz
  • Variable Bass EQ: 0dB - +10dB
  • Phase Shift (0 - +180 degrees)
  • Unbalanced Inputs (RCA)
  • Balanced Inputs (DIN)
  • Line Output (RCA)
  • Speaker Terminals (molded): 12ga
  • Power/Ground Terminals (molded): 0ga
  • Remote Bass Module: HFR-3
  • Parametric bass EQ with 45Hz bass boost and variable control from 0db to 10db
  • Variable Low Pass, Subsonic Filter, Phase Shift and Level Control
  • Balanced line input for MX accessories and line drivers
  • Bass Remote included
  • Built-In System Diagnostics protects from short circuits, over load, thermal overheat and DC Offset.
  • Dimensions 14.17" x 2.52" x 9.45"
Subs:
Sensitivity: 86 dB Peak Power Handling: 1200 Watts Impedance: Dual 2 Ohm Diameter: 12 Inch
Illuminated Cone
Polypropylene Cone with woven honeycomb structured support body
Stitched rubber surround for big excursion
3" voice coil on a glass fiber former
100 Oz. Magnet
Ported Nickel Plated Back Plate
Injection molded cone neck support
3. Descriptions/Condition of all items:
Used, Like New, 10/10 Mechanically. 8/10 Appearance, Few Scratches.
4. Total Price: :
$425 shipped
1 - 6 of 6 Posts
