How 2 wire down 2 .5 or lower
1086 Views 32 Replies 8 Participants Last post by  mlstrass
amp aq 3500.1
subs 2 hdc3 12A d1
im new 2 this just need some help thanks guys
1 - 20 of 33 Posts
with two D1s you'd be at .25 or 1ohm.
If you simply took all the positives and ran them to the amp and all the negatives and ran them to the amp( to their respective terminal of course) then it would be .25ohm
This is called wiring in parallel.
If you took a positive and connected it to a negative from the opposite set of terminals on EACH sub and then took the set of wires you had left and ran them to their respective terminals on the amp then you'd be at 1ohm.
This is called wiring in Series/Parallel.
Recone them to d2s. Otherwise you have .25 or 1 ohm
ok thanks is it safe 2 run the amp and the subs that low
No
Subs yes amp no
ok thanks who can do a recone on the subs plus they are brand new never been played
Subs yes amp no
is there a amp i can run that low
just run them at 1 ohm, will be plenty power
See if you can ship them back for a pair of d2s. You might have to pay shipping or something but it beats paying someone to recone a perfectly good sub that you would have to ship them anyway.
I wouldn't recommend any amp at .25 ohms daily. Which brings me to the question of is your electrical even stout enough for .5 with your current amp?
if he is asking then no :lmao:
I also agree with the run them at 1 ohm comment.
True I did forget that the question at hand was how to wire for a different load.
ok i think aq is not offering d2 4 the aluminum coils right now thats what mike said well have have 6 80ah in the back and a 60ah in the front and a dc power 270xp is that cool
for .5 ohm, it should be enought...
What racer said.
Well your options are run it at 1 ohm which is a good option since that's still a good deal of power. Or recone them with another companies recone kit that fits and are d2s.
do u know how mush power the amp will produce at .5 and what is the pros and cons of running it that low thanks
depends on everything, maybe 4k, id run it a 1ohm because its less current draw than .5 and the amp will last alot longer at 1 ohm over .5
kyle
ok cool but where im confused now is that the amp is rated at [email protected] 1 but at .5 its 4k by u guesstamation
kyle
1 - 20 of 33 Posts
