1 - 2 of 2 Posts
Tinder Douchebag
I got some a pillars at the junk yard to mess around with tweeter placement.
Not sure how to make some mdf rings with a slant or with more area on one side since I need to space out the back to go off-axis (pointed at each other)
I have a jig saw, 4-1/2 circular, sawzall, multi tool.
Do I need a router? I have a box of 20 new bits, all different.
For a 2010 hhr
Going with the 80w vifa silk dome about middle of the a pillar
I believe, generally when needing that much variation and angles, most people fiberglass. Be easier to get the kind of angle your looking for I would think. Otherwise you could try making multiple thin rings, and stack them, then slice out needed angle. Good luck!
(Also, a router makes life sooo much easier and really opens up your possibilities.)
1 - 2 of 2 Posts
