Hey I had a few questions and I thought it would be easier just to put it into 1 posting...
1.What exactly is "Clamped Power" on your amp and how do I do it? Everyone is always talking about their clamped numbers and I have no idea what it is
2.How would I run a higher voltage system/turn the voltage up?If I got a Kinetik HC16V battery as a 2nd battery in my trunk, that hooks up to the amp, would that make my amp at 16v or is that bad? I hear people talking about Voltage regulators, is that a way to turn up and down my voltage when I want and if so where does it get installed at?
3.What do you suggest my electrical system to consist of for me to run TWO Sundown SAZ-1500d V.2's STRAPPED @ 1ohm?I currently have a Optima Yellow Top up front,2awg power wire,200amp anl fuse,220 amp power bastards alternator,10% Alternator Overdrive pulley,BIG 3,.6v volt booster and 5 farad cap. Voltage stays at 15.0 and never drops below 13.9 during hardcore bumping, idling at a light..
I was considering adding a 2nd battery in the trunk along the lines of kinetik or something like that, Would I be able to to run ONE 0awg Power wire from front Yellowtop to the rear 2nd battery and then I can run 2 0awg wires off that rear battery to the 2 amps right?
I'm probably going to need some help knowing what exactly to do to put a 2nd battery in the trunk and also what wires go where to strap 2 amps together. If someone could PM me letting me know I would greatly appreciate it
