Whenever you put a new basket or whatever on it, use RUBBER glue for the motor to the basket connection, then use all the screws, it will stay on, and if you ever switch sizes or anything, a tap or two and it will let loose, but even with all the screws loose it won't fall off. Only thing with using CA is you will have a hell of a time getting the basket off if you need to ever again. Essayacademia[dot]com
