1 - 20 of 48 Posts
i tried that, it seemed like it didnt wanna go through, maybe ill try it again tho.
i asked for help, not *******s. geez.
TM, thats not frayed wire...
Administrator
simple fix.
throw it away.
sorry Howie.
fair enough
guys it's not even howie who did it :dontknow:
I'm not putting him down. That screw isn't coming out. the material has gone molten.
just my opinion I guess
Looks like it arcedand melted, which my give you problems. Do you know what size set screw it was? That way I can tell you what size to drill to be able to re-tap it. This way may work as I can still somewhat see the center of the screw. That is where you want to drill or try to.
Discussion Starter · #16 ·
i do not know off hand, sorry
Start with a small 7/64" drill bit. That will give you some room to play if you need to retap it.
Also may need to take a dremel with a burr if you have one, and clean up around the screw where it looked like it had melted to the parent metal.
Administrator
actually, on second look, it appears the screw is still up at the top. {the rest is just terminal block exposed}
get a "center punch" and center punch it, and then use a 7/64" drill bit. {reverse if you can get one} and drill it out, then use a small screw extractor to remove it.
Discussion Starter · #19 ·
thanks guys, you've been a big help(besides GLM)
ill will try this tomm!
1 - 20 of 48 Posts
