1 - 20 of 43 Posts
1. Product: Incriminator Audio 40.1 Class D Amplifier
2. Specs: rated at 3600 @ 1 ohm but we all know it will do a lot more than that
3. Description/Condition: Has a few scratches one big scuff shown in pics. I had amp mounted to box and I blew it and sent it to chris at db-r and had it fixed been working fine ever since and of course never mounted to box again.
4. Price: :$650 shipped
Discussion Starter · #14 ·
I really don't know. I know these amps are built like a tank and it is very hard to get them to go into protect even from very very low ohm loads. Yes if I'm not mistaken these will play on 18 volts easily I'm almost 100% positive. and the power it makes at 18 volts I do not know but I wouldn't be surprised if you saw around 6000 watts out of this thing at 18 volts.
2 300 amp alts running 18v and single 250 for 12v. :) lol if i knew they wouldnt go into protect at 19.2 id get this from you
How long was it ran since repaired? Just making sure it will hold up. Also what electrical and impedance was it installed with?
Discussion Starter · #20 ·
I've ran it for about 3 months since it was repaired. I have a gm 225 amp excessive amperage alternator kinetic 1400 under hood and spv 70 in my trunk. I rarely let it drop below 13 volts because it would start making my subs stinky. oh and it was at 0.5 ohm. Has never given me any problems. And when it blew it I had the music down and heard the tiniest little pop and immediately turned the car off and opened it up and couldn't find any burn marks on the board whatsoever but I didn't hook it back up I sent it to chris @ db-r right away cause he is very familiar with these amps
1 - 20 of 43 Posts
