1 - 10 of 10 Posts
anyone kno what a good 8v line driver other then a maxxlink
Concert Series Overdrive Line Driver
Ensures that your amp sees the cleanest signal possible
Boosts the signal from your receiver up to 24 dB
High voltage level keeps the noise out of your system
Balanced inputs reject noise caused by your vehicle's electrical system
Low-Impedance output keeps your signal going strong through long cable runs
Top-Mounted controls for easy adjustment
2-Channel preamp inputs and outputs
Light indicates 2-, 5-, or 7.5 volt output
Power supply ground is switchable in case of ground loop noise
Frequency Response: 10-100,000 Hz
THD (Total Harmonic Distortion): 0.005%
Signal-to-Noise Ratio: >110 dB
Input Impedance: 20k ohm
Output Impedance: 45 ohm
Maximum Output Level: 9.5 volts RMS, 13 volts peak
Fuse Rating: 1 amp
Six Channels of Input and Output
24 dB of Signal Gain - 13 Volts Peak Output
12 dB of Signal Attenuation
PFM Subsonic Filter
Output Level Controls
Balanced Differential Inputs
Linkable Inputs - 2 Input Channels to 6 Output Channels
Low Impedance Outputs
Voltage Indicator LEDs
"None" is the best one I've ever used. Very reliable line driver.
1 - 10 of 10 Posts
