Infinity 5350A Broken
443 Views 2 Replies 1 Participant Last post by  My08FXT
5
Infinity REF 5350A
  • Height: 2-11/16"
    [*]Width: 9"
    [*]Weight: 17 lbs.
    [*]Depth: 16-9/16"
    [*]Continuous Watts per Channel (4 Ohms) RMS 50 x 4; 150 x 1
    [*]Continuous Watts per Channel (2 Ohms) RMS 60 x 4; 300 x 1
    [*]Peak Power Watts per Channel (4 Ohms)50 x 4; 250 x 1
    [*]Peak Power Watts per Channel (2 Ohms)75 x 4; 350 x 1
    [*]Number of Channels 5
    [*]Crossover Variable
    [*]Amplifier Class and Type Class AB
    [*]Bass Boost Yes
    [*]Signal-to-Noise Ratio 85dBA
    [*]Bridgeable Yes
I've had this amp for 2 years and it's been great. My wife spilled some coffee on it and a tiny, tiny bit got inside (from the top). I don't think that's the reason it crapped out but I'm giving you full disclosure. I think I had the gain too high on the sub and that's what's what toasted it, but I'm not sure. Anyway it will work for about 5 minutes then there'll be a loud pop that's it - no sound. The protect mode light doesn't go on. I opened it up and there is a small amount of white residue (see 1st photo, top left) and a few of the small capacitors have expanded. Other than that there are a few minor scratches on the outside.
$40 (OBO) and you pay for shipping (from zip: 32966)
6. Pictures:
1.
1 - 3 of 3 Posts
Price Break!!!!! $30 OBO - come on there's gotta be something you could use from this amp or, if you're electronics savy, this prolly would be a pretty easy fix...
1 - 3 of 3 Posts
