1 - 11 of 11 Posts
1. Product: MTX Thunder 2300X
2. Specs: RMS Power measured at 12.5 Volts DC:
150 Watts x 2 into a 4 Ohm load with less than 0.05% THD+N
300 Watts x 2 into a 2 Ohm load with less than 0.1% THD+N
600 Watts bridged into a 4 Ohm load with less than 0.1% THD+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
200 Watts x 2 into a 4 Ohm load
375 Watts x 2 into a 2 Ohm load
750 Watts bridged into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions:
13" x 9" x 2" (33cm x 22.8cm x 5cm)
14-1/4" x 9" x 2" (36.2cm x 22.8cm x 5cm)(with feet)
3. Description/Condition: Great used condition, a couple scratches, but nothing some touching-up wont fix. All controls are functional, and the pots are smooth. Amp was serviced by local technician about 2 years ago. Drives a sealed Avalanche 15D2 to just shy of 140dB @ 37Hz in my Tahoe (vids available if requested).
4. Price: : Asking $200 shipped via USPS Priority.
http://i1219.photobucket.com/albums/dd437/M_E_Bolstad/2300x_2.jpg
http://i1219.photobucket.com/albums/dd437/M_E_Bolstad/2300x_3.jpg
http://i1219.photobucket.com/albums/dd437/M_E_Bolstad/2300x_4.jpg
1 - 11 of 11 Posts
