1. Product: [/B]
MA Audio HK802SX
4400W RMS 2-Channel High Current Amplifier
500W RMS x 2 @ 4 Ohms Stereo
800W RMS x 2 @ 2 Ohms Stereo
1400W RMS x 2 @ 1 Ohm Stereo
2200W RMS x 2 @ 0.5 Ohm Stereo
4400W RMS x 1 @ 1 Ohm Bridged
Digital LCD Display (Voltage, Temperature & Output Level)
Platinum Plated Connections
Quiet Fan Cooling System
High Quality Power & Protection LED’s
Thermal / Short / Overload Protection Circuitry
0-18 dB Variable Bass Boost
40-250Hz Variable High Pass Crossover
40-250Hz Variable Low Pass Crossover
Remote Bass Control
THD @ 4 Ohm <0.05%
THD @ 2 Ohm <0.1%
THD @ 1 Ohm <1.0%
S/N Ratio: >90dB
Channel Separation: 60dB
Frequency Response: 20-20kHz
Input Voltage Range: 200mV - 8V
Input Impedance: 10k Ohms
Dimensions: 2.7" H x 12.4" W x 27.3" L
Mechanically 9/10 comsmetic 7/10. There are some scratches and dings. normal wear. This thing is a beast. I had it running two HK12's for several years with no problems. Sold the car and the subs so i have no need for the amp.
$300 o.b.o possibly trades just let me know what you got. thanks
MA Audio HK802SX
Remote Bass Control
THD @ 4 Ohm <0.05%
THD @ 2 Ohm <0.1%
THD @ 1 Ohm <1.0%
S/N Ratio: >90dB
