1 - 6 of 6 Posts
Ad ministrator
How much would a 250+amp alt cost for my 97' buick park avenue?
I just want an estimate.
Also for anyone else, could I just get 2 stock alts and run dual alts? Because my stock one is 105amps.
EDIT: Could a mod please move this to MechMan's forum... I never released he had one.
That vehicle requires a large case conversion kit, which inlcludes the necessary adapter brackets, it is $499 for the 250 amp Rhino series.
You can run dual stock alts, but good luck finding the room for them.
Thanks
MAtt
Ad ministrator
How could I hook up 2 alts?
Would I just run wire from the original alt to the second alt?
Ad ministrator
Mech man, you there? How would I hook up the second alt?
habitual line stepper
If you're running 2 alts you will have to get a wiring harness for your second alt, and run it as a 1 wire alt. I'm not to sure if you can chain all of the wire together.
Ad ministrator
Ok thanks, hopefully Mechman can explain it.
1 - 6 of 6 Posts
