nope. not pico fuse.
you probably have a crappy RCA end. {try other RCAs}
um... that's prolly not good
you deck has RCAs
why would you? wait what?
when you go to that position either the fuel pump, blower motor or some electrical motor is running and sending noise through the ground circuit. Either move your amp ground or try grounding your RCA's...When I say turn the key over Im not talking about turning the car on just the last click you have ! !! !!! clicks.With the car sitting I turn the key to ! it plays fine But when I actually turn it over to where it would be on it has the noise.
Exactly what I was thinking......That is not at all a good idea....guys, near as I can tell. he has cut RCAs off and connected them to his speaker leads which go to his factory amp.
The fuel pump/heater fan noise is probably induced and will not go away until he either gets rid of the factory amp or finds another way to connect it.
dude.
cutting RCAs and connecting them to speaker wire is not cool.
move the ground from the headunit is only ground I can move.The amp ground is under driver seat.I understand grounding the rcas but why does it only bother the right side channelswhen you go to that position either the fuel pump, blower motor or some electrical motor is running and sending noise through the ground circuit. Either move your amp ground or try grounding your RCA's...
