1 - 10 of 10 Posts
Ja Marcus
You can either bridge the 2 channels and run series/parallel. Or you could parallel each sub and run it on its own channel. You should get the same power either way. But the amp will run a bit better in 2 channel over bridged.
2 Ohm load, Amp bridged
1 - 10 of 10 Posts
