1 - 3 of 3 Posts
I have plenty room everybody always ask for dimensions of my trunk so just give me some measurements for 2 audioque hdc312's. Thanks guys.
Not too good with those subs but I'll take my best shot. If memory serves me right you need approx 2.0 cu ft per sub. If room isn't a problem I'd go with
Width:40"
Height:16"
Depth:16"
Which would give you 4.68 cu ft but port space and displacement also take up some space.
EDIT:The reason I say to make the box as wide as I said is cause I'm pretty familiar with ''Vic'' trunks with the gas tank being a big box under the carpet in the trunk so I tried to minimize the depth as much as possible and make it up in width since width isn't a problem in these cars.
EDIT:I'm sorry I forgot to add specs for the port.
I'd do this for design from left to right of the box (sub) (sub) (port) port specs below for 38 hrtz tuning.
Width:3"
Height:14.5" -assuming 3/4" MDF wood-
Length of port:11.9"
Not sure how many square inches of port is needed for those subs.. but lemme know what you think.
1 - 3 of 3 Posts
