3
USD HLCD waveguides (roto mount) with Selenium DH200E-E drivers
Nominal impedance. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
[email protected],250 H z . . . . . . . . . . . . . . . . . . . . . 6.9
Frequency
[email protected] dB. . . . . . . . . . . . . 1,500 to 20,000 Hz
Power handling Musical Program(w/ xover 2,000 Hz 12 dB / oct) . . . 200 W
Sensitivity On horn,
[email protected], on axis . . . . . . . . . . . . . . . . . . . . 105 dB SPL
Throat diameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 (1) mm (in)
Diaphragmmaterial . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Titanium
Voice coil diameter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 46 (1.8) mm (in)
Re . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.8
Flux density . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.55 T
Minimumrecommended crossover (12 dB / oct) . . . . . . . 2,000 Hz
waveguide body:
USD Audio WaveGuides
driver:
http://www.parts-express.com/pdf/264-225.pdf
Selenium DH200E-E 1" Titanium Horn Driver 1-3/8"-18 TPI | Parts-Express.com
The waveguides are used and have normal mounting flange holes. Waveguide body is in very good used condition. I recently bought these but decided to go a different route. I tested the drivers with approx. 1w and they are very loud.
4. What you are looking for: :
I will trade for a +200x2(4ohm) or a +100x4(4ohm) amplifier. Amplifier has to be either BNIB or in excellent used condition.
5. Pictures of your item for trade:
