I just got some 8ohm speakers that im running bridged on a 2 ch for shows and im having a hell of a time figuring out the uF value for this setup....
basically each speaker is 8 ohm
i wired them in parallel so thats a 4ohm load and then bridged the amp so each channel of amp sees 2ohm
i connected 2 47uF caps in parallel which should give me roughly a 400hz
x over point @ 4ohm correct?
or do the caps see a 2ohm load bc of the amp being bridged?
i am thoroughly confused.....
