I like option 2
but the off to the side batts arent connected to each other.if it was me,option 1 because its the most direct
they connect together on the buss bar, the less connections stacked on top of one another the less potential for problems(loose connections from vibration,corrosion ect..)but the off to the side batts arent connected to each other.
id do 3. even though 2 and 3 are the same just with different spaces
How aren't they connected? All the batteries are connected to a common buss bar. If you take the batteries and rotate them sideways they would be connected in the same way as if they were in the row.but the off to the side batts arent connected to each other.
you are definitely right, we're going to add longer cables next timeI would spread the wires going to the amp out a little more. The batteries towards the end may not get discharged as evenly the way it is now.
:goodjob: now we want to see some TL #s and pix of the rest of the install
