1 - 20 of 27 Posts
2 Stinger SPV70's
Stinger's POWER Series batteries offer many of the same technologies as our remarkable Power2 series at an outstanding value. The valve regulated, sealed lead acid battery utilizes dry cell technology with an absorbed glass mat for performance that comes just short of the POWER2 but far ahead of other batteries! This makes the POWER series the perfect choice for excellent Dry Cell performance on a budget.
  • <LI type=square>Internal resistance <4 mOhms
    <LI type=square>5 Second Cranking 1050 Amps
    <LI type=square>Weight 57.3 lbs Constant Discharge Capacity at 77 degrees to 10.50 Volts:
    <LI type=square>20 hour rate: 3.5A/70Ah
    <LI type=square>5 hour rate: 11.9A/59.5Ah
    <LI type=square>1/2 hour rate: 87.5A/43.75Ah
    <LI type=square>CCA: 875 Amps
    DIMENSIONS
    <LI type=square>SPV70 6-7/8" H x 13-3/4" W x 6-1/2" D
    <LI type=square>(Add 5/8 to height for battery post)
    General POWER Series Specifications:
    <LI type=square>Temperature Range: -15 to +50 C
    <LI type=square>Typical Cycle Life: 350 cycles @ 100% depth of discharge (10.5v)
  • Maximum Charging Voltage: 15 Volts (Cyclic Use) 13.8 Volts (Standby Use
Used/Working. Rest at 12.9 straight out the car
4. Price: : $100 each plus shipping firm
TEAM SHOK
You interested in any trades I ned another one of these
TEAM SHOK
I have an audiopipe 1500 that I will trade ya for one. Does close to 1500 at 1 ohm
do you have the metal jackets for them?
1 - 20 of 27 Posts
