1 - 1 of 1 Posts
Super Moderator
1. Products:
5 MB Quart RAA Amps, Mono, 2 channel x 3, Blown 4 channel
I'm selling off these amps as it took me over 2 months to get them, and now I won't even be using them more than likely.
All 3 2 channels work, mono works, all have ALL the plugs, mono only came with one on the speaker side from what I was told, remote gain control is also included with the mono. Also the 4 channel is blown. 2 come with OG box as well.
These amps were built by RF. They are all heavily underrated, they'll all do about 35% more power than rated.
I'm looking for $900 shipped for all 5 amps.
Ratings:
RAA1000 MONO:
The Reference Series RAA1000 amplifier from MB Quart delivers the high-end performance and reliability you need for a serious audio system. Housed in a sleek, low-profile black chassis, this mono powerhouse can produce up to 1,000 watts to multiple subwoofers. Its convenient top-mounted controls make tweaking the output a snap, while removable end caps hide all of the wiring for a professional-looking installation. Use the built-in low-pass filter to get the best sound out of your subwoofer/box combo, then adjust the subsonic filter to eliminate the inaudible, ultra-low bass that can hamper performance. You also get a set of preamp inputs and outputs for tapping into your other audio components — flexibility that means this amp can be incorporated into just about any system.
If you're using an outboard preamp or crossover, you can bypass the amp's built-in gain and crossover controls for a cleaner sound. The included remote level controller lets you adjust low-frequency impact right from the front seat. And all Reference Series amplifiers are exactly the same size, so your MB Quart multi-amp setup will look perfect.
Details:
The Reference Series RAA4200 amplifier from MB Quart delivers the high-end performance and reliability you need for a serious audio system. Housed in a sleek, low-profile black chassis, this 4-channel powerhouse produces plenty of power to drive your subwoofers or speakers. Its convenient top-mounted controls make tweaking the output a snap, while removable end caps hide all of the wiring for a professional-looking installation.
Use the built-in low- and high-pass filters to get the best sound out of your system. If you're using an outboard preamp or crossover, you can bypass the amp's built-in gain and crossover controls for a cleaner sound. You also get a set of preamp inputs and outputs for tapping into your other audio components — flexibility that means this amp can be incorporated into just about any system.
Separate LED indicators warn of distortion in either the front or rear channels. And all Reference Series amplifiers are exactly the same size, so your MB Quart multi-amp setup will look perfect.
RAA2400 2 CHANNEL:
The Reference Series RAA2400 amplifier from MB Quart delivers the high-end performance and reliability you need for a serious audio system. Housed in a sleek, low-profile black chassis, this 2-channel powerhouse produces plenty of power to drive your subwoofers or speakers. Its convenient top-mounted controls make tweaking the output a snap, while removable end caps hide all of the wiring for a professional-looking installation.
LED indicators warn of distortion, handy when you're tuning up your system. And all Reference Series amplifiers are exactly the same size, so your MB Quart multi-amp setup will look perfect.
3. Descriptions/Condition of all items:
4. Total Price: :
$600 obo
1 - 1 of 1 Posts
