American Bass Vfl-400.1
Specs taken right from AB's website!
I OHM STABLE D CLASS MONO BLOCK AMPLIFIER
LOW LEVEL INPUT AND OUTPUT
FREQUENCY RESPONSE: 20Hz~350Hz
INPUT LEVEL: 0.2V~6V
VARIABLE SUBSONIC: 10Hz~50Hz AT 24dB/OCT
VARIABLE LOW PASS FILTER: 35Hz~250Hz AT 24dB/OCT
VARIABLE BASS BOOST: 0~9dB AT 45Hz
REMOTE GAIN CONTROLLER
TWO AMPLIFIERS LINKABLE CONNECTOR AND SELECTOR
FUSE RATING-350 AMPS, LINKED FUSE RATE, 700 AMPS, USES EXTERNAL FUSES
EXTERNAL FUSES AND FUSE BLOCKS ARE NOT USED
4600 Watts
I have owned this amp since 11/02/2008 so I have had it relatively long. It is in immaculate condition and has never had to be repaired. It has been powering my AudioQue Hdc315’s. My electrical powering this amp was 2 Stinger Sp1700’s, 2 runs of knu 1/0 klmx, and an optima yellow top. I will accept pay pal only! This amp is in great working condition, and is Sold As Is. I can shoot a video of it working if you would like. Below are pictures that I have taken. This amp looks extremely clean, and has maybe 1 or 2 scratches total. This is a huge obo here people!
$710 (OBO)
4600 Watts
$710 (OBO)
