1 - 20 of 28 Posts
american bass vfl 400.1
  • Frequency Response: 20Hz ~ 350Hz
  • Signal to Noise Ratio (A-Weighted): 85dB <
  • Damping Factor: 200 <
  • Efficiency: 70% <
  • Variable Gain Control: 0.2V ~ 6V
  • Variable Subsonic Filter: 10Hz ~ 50Hz @ 24dB
  • Variable Bass Boost: 0 ~ 9dB @ 45Hz
  • Variable Low Pass Filter: 35Hz ~ 250Hz @ 24dB
  • Variable Phase: 0 ~ 180 Degrees
  • Dimensions (in inches):
  • Width: 10.16"
  • Height: 2.60"
  • Length: 25.59"
used and its missing a bottom plate. u can use plexiglass to make a bottom
700 shipped
650 shipped
Whats the 4 ohm rating?
1300 x 1 @ 4 ohm , 2600 x
1 @ 2 ohm and 4000 x 1 @ 1 ohm
Isn't it like 4k at 16volts? I heard that's wat they rated them at
Discussion Starter · #9 ·
its rated to14 volts 4k but u can run this up up to 18 volts from what bob has to me.
1 x 1300W @ 4 ohms (14.4V - <0.1% THD)
1 x 2600W @ 2 ohms (14.4V - <0.1% THD)
1 x 4000W @ 1 ohm (14.4V - 1% THD)
1 x 5200W @ 1 ohm (16V - 1% THD)
1 x 6000W @ 1 ohm (18V - 1% THD)
Discussion Starter · #16 ·
ill trade for a saz 3000 or saz 3500
Discussion Starter · #17 ·
600 shipped
Discussion Starter · #18 ·
i need this sold bad. i have a court date soon
1 - 20 of 28 Posts
