1 - 16 of 16 Posts
DC 5k
The 5.0kw competition series amplifier is a 5000 watt mono block. Its capable of running up to 18 volts for up to 7300 watts. It is a linkable amp and designed to run a 1 ohm per amp or 2 ohms when strapped. It comes with a bass knob and a clipping indicator. For power inputs it will accept dual 0 awg for power and dual 0 awg for ground.​
Key Features
1 ohm stable
Variable low pass filter
Variable subsonic filter
Variable bass boost
Wired remote control
Clipping indicator
Dual 0 awg power and ground inputs (both must be used)
We recommend for installation
1 upgraded battery under the hood
1 extra 800ci battery in the rear
Minimum of two 0 awg ran from the front battery to the rear battery
Both 0 awg power and ground inputs on amp must have 0 awg ran to them for a total of 4 runs into the amp
Upgraded aftermarket alternator
Dash mounted voltage meter
ItemsFeaturesVoltage5.0kwOutput Power (RMS)at 4 ohm14.4V900W x 1at 2 ohm2300W x 1at 1 ohm5000W x 1at 1 ohm16V6000W x 1at 1 ohm 18V7300W x 1Input Sensitivity 6V~0.2VLow Pass FilterSwitchable ( @ 24 dB Slope)VariableHz35~250Subsonic FilterSwitchable ( @ 24dB slope )VariableHz10~50Bass BoostVariabledB0-9dBFrequency Response Hz15-270Signal to Noise Ratio dB100Damping factor 150<Efficiency @ 4ohm %Over 90%THD @ 4ohms Less than 0.1%Fuse Rating 500 AmpsLinked Fuse Rating 1000 AmpsIndicatorPower YesProtection YesClip YesSpeaker & Power terminalMold Type YesPowerGauge0GaHeatsink Lengthinch/mm 25.59"/650mmHeatsink Widthinch/mm 9.38"/66mmHeatsink Heightinch/mm 2.35"/59.6mm​
used for 1 days at show last weekend not 1 scratch on it taped mounting feet...bass knob and all orig packing
4. Price: :950 shipped OBO no lowballers you pay paypal fee
You clamp this at all?
is this really [email protected]? and do you know where i could find a second 1 im interested but if i got it i would need a second 1 for usaci!
1 - 16 of 16 Posts
