1 - 13 of 13 Posts
Digital Design Z1A
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
Subsonic Filter
10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter
35 Hz - 250 Hz at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
Z1a
Cont Power at 4 ohm
1250W-1750W x 1ch 12v - 14v
Cont Power at 2 ohm
3500-4000W x 1ch 12v - 14.4v
Damping Factor
>450 @ 1 ohm
Cont Power at 1 ohm
5000W-5500W x 1ch 12v - 14.4v
Dynamic Power
7072W x 1ch
Efficiency thru Output
>86% 14.4v
Dimensions - mm
685.8 L x 304 W x 70 H
Dimensions - inches
27 L x 12 W x 2.76 H
Signal to Noise
85 dB
Shipping Weight
43 lbs
Used but in perfect condition. Had the board replaced by DD AND carries a 90 day warranty. Just got it back last week and I haven't even taken it out of the box besides to take pictures.
Mechanical 10
Cosmetic - 9 for some minor scratches
$800 shipped to lower 48 NO TRADES just need the cash
tempting
should raffle it.
CACO Fanatic
some one lend me the money so i can get this
How about I lend you $407.50 and you do the same for me. And then we combine our money 2gether and then buy it. And then we can take turns on using it. Great plan.:thumbsup:
CACO Fanatic
Any trades:confused:
1 - 13 of 13 Posts
